Group: DynoMotion Message: 5388 From: himykabibble Date: 7/1/2012
Subject: Power-Up Configuration?
Is there a way to set the power-up I/O configuration, before any user program is loaded? I have a stupid relay board that energizes all relays until the I/O configuration is set, and the associated I/Os are all set high. I'd like the KFlop to just power-up in that state. Can it be done?
Ray L.
Group: DynoMotion Message: 5396 From: Tom Kerekes Date: 7/2/2012
Subject: Re: Power-Up Configuration?
Hi Ray,
Not really.  You can Flash a User Program to Launch on Power Up and configure al the IO but there will still be a few seconds while KFLOP is booting.  This also has a disadvantage of needing things pre-flashed in the board which complicates upgrading to new versions or replacing hardware.
Consider having one relay to keep all power off until your Init.c program is executed.  Your Init.c program will then be able to handle things in the proper order of initialization.
